Newbie
Accepted Solution
Play m4p from Wireless Stick on iPhone
I just purchased a SanDisk Connect Wireless Stick. I copied all of my songs from my phone and iTunes to the stick. I now want to play them on my iPhone. They won't play directly from San Disk Connect. How can I play them without first copying to the iPhone? I bought this because my iPhone is maxed out on memory.
SanDisk Guru
Re: Play m4p from Wireless Stick on iPhone
m4p are DRM protected files. you will need to remove the DRM protection from the file or convert the file to a compatible format  in order for the connect drive app to play it.
