Newbie
Accepted Solution
Map Wireless Stick As Network Drive?
[ Edited ]
I apologize if this has been asked before.
I have tried to setup my 16gb Wireless Stick as a network drive on Windows 10.
The only problem is that it isn't reporting the correct size, and I also get a weird error when trying to move over any documents.
I just wanted to do this for the sake of convenience, but I am beginning to think that I will forever have to go through the web interface.
Is there something that I am missing?
Errors
Thanks in advance.
SanDisk Guru
Re: Map Wireless Stick As Network Drive?
this product does not support being mapped as a network drive. wifi access on a computer is limited to the web interface.
