I have a Sandisk connect wireless stick.
I am able to connect to it using in all android phones, But only in my onePlus 6 (android 10 Oxygen 10.3.1) its not working.
It is connecting to the disk wifi name in settings app but sandisk connect app is not showing any data.
Does anyone else is facing this issue ? or some one has an answer to this already?
Thanks in Advance!
Gokul
I understand your concern about the SanDisk Connect Wireless Stick not working with your OnePlus 6. It’s frustrating when a device doesn’t cooperate as expected.
To address this issue, here are a few steps to try:
Make sure your SanDisk Connect Wireless Stick has the latest firmware updates.
Ensure that the SanDisk Connect app on your OnePlus 6 is up to date.
Try restarting both your OnePlus 6 and the Wireless Stick and attempt to connect again.
If you ever encounter freezing issues with your iPhone, you can find guidance in a troubleshooting guide for iPhone freezing issues. Having resources for tech problems can be quite helpful.
