Highlighted
Newbie
Camera Roll Backup and transferring pics
I am having trouble getting all of my pictures from my phone onto the disk. I turned on camera roll back up and it only transferred 210 pictures of 2800.  I have tried to transfer the pictures individually and it just keeps buffering. Any suggestions or help is greatly apprecitated. I have the 200gb and I have talked with sandisk customer support who were not able to help either.
Thank you
Highlighted
SanDisk Guru
Re: Camera Roll Backup and transferring pics
are the pictures actually on the phone or on they on iCloud? When you open the iOS pictures app if you see All pictures as one of the albums you have iCloud photo sharing turned on. The WS app cannot backup pictures stored on the cloud it can only backup pictures stored locally.
If you only see camera roll in the iOS pictures app then iCloud photo sharing is turned off. If this is the case all the pics should be stored locally. Try transferring them in smaller chunks. See if that helps.
Highlighted
Newbie
Thank you so much for explaining this!  It looks like I do have icloud turned on. Should I turn it off?  When I go to that it asks if I want a copy of the icloud photo library to this phone. What should I do?  Thank you
Highlighted
SanDisk Guru
it really depends on what you are looking to do. If you are not using the cloud service you can turn it off. If it asks you if you want to copy the files from the cloud to the phone make sure you have enough free space. If you do once that is done you can use the WS app to backup all the pictures then you can delete them from your phone if you need to free up space.
Highlighted
Newbie
Thank you again!  I will look into that and see how it goes. Hopefully I can get this to work.  Disapointing that the sandisk support guy that I chatted with never had a solution like this!  Thank you
