Newbie
Accepted Solution
Unable to connect to WMD wirelessly
[ Edited ]
https://www.dropbox.com/sc/270yjnz2d95xujr/AAB433sMVbQCEIJPd8FGs6q5a
https://www.dropbox.com/sc/l9g434p63f6dfws/AABhW0zOr3T1uGek5_3M78_ha
The warning saying that usb is connected keeps popping up. I tried had resetting, and I also couldn't reset the admin password for it.
SanDisk Guru
Re: Unable to connect to WMD wirelessly
the dropbox links show an empty album.
If the drive is not connected to a computer via USB and you are getting that error and the reset is not working you will need to contact sandisk support. the drive is most likely defective and would need to be replaced.
