Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Media Drive losing network connectivityOptions
08-15-2015 02:50 PM Hello,
A year ago I bought a 64GB SanDisk Connect Wireless Media Drive. The drive has worked without any issues, but since this week (I am at my holiday location) the Media Drive is not working stable en needs te be restarted several times in an hour to keep working.
The problem is likely WiFI related. De drives loses its internet connection and also is not reachable via WiFi.
I found out I can telnet to the mediadrive and found some logfiles that show errors during the problems:
The sys.log file show errors like:
Aug 15 20:59:44 Media_Drive klogd: [ 494.353696] wl12xx: WARNING cmd set_template failed: -110 Aug 15 20:59:44 Media_Drive klogd: [ 494.359418] wl12xx: ERROR PROBE request template failed Aug 15 20:59:44 Media_Drive klogd: [ 494.364669] wl12xx: Hardware recovery in progress. FW ver: Rev 6.5.7.0.29 Aug 15 20:59:44 Media_Drive klogd: [ 494.372216] wl12xx: pc: 0x8f4c Aug 15 20:59:44 Media_Drive klogd: [ 494.375285] wl12xx: down Aug 15 20:59:44 Media_Drive klogd: [ 494.378131] wl12xx: down Aug 15 20:59:44 Media_Drive klogd: [ 494.582560] WLAN-EN Aug 15 20:59:44 Media_Drive klogd: [ 494.585051] ieee80211 phy0: Hardware restart was requested Aug 15 20:59:44 Media_Drive klogd: [ 494.592677] wl12xx: open_count=1, add=1, current_fw=0 Aug 15 20:59:44 Media_Drive klogd: [ 494.597740] wl12xx: state: 0 Aug 15 20:59:45 Media_Drive klogd: [ 494.830854] WLAN-EN Aug 15 20:59:45 Media_Drive klogd: [ 495.240309] wl12xx: firmware booted (Rev 6.5.7.0.29) Aug 15 20:59:45 Media_Drive klogd: [ 495.250370] wlan1: authenticate with 4c:5e:0c:11:f0:b3 (try 1) Aug 15 20:59:45 Media_Drive klogd: [ 495.250434] wl12xx: open_count=1, add=1, current_fw=2 Aug 15 20:59:45 Media_Drive klogd: [ 495.255490] wl12xx: state: 1 Aug 15 20:59:45 Media_Drive klogd: [ 495.316700] wlan1: authenticated Aug 15 20:59:45 Media_Drive klogd: [ 495.611289] wlan1: deauthenticating from 4c:5e:0c:11:f0:b3 by local choice (reason=2) Aug 15 20:59:47 Media_Drive klogd: [ 497.127857] ------------[ cut here ]------------ Aug 15 20:59:47 Media_Drive klogd: [ 497.132579] WARNING: at /home/qsi/freescale/source/TI/R5_SP1_Maintenance_Release_1/compat-wireless/drivers/net/wireless/wl12xx/main.c:1532 wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]() Aug 15 20:59:47 Media_Drive klogd: [ 497.149645] Modules linked in: wl12xx_sdio wl12xx mac80211 cfg80211 compat ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter tntfs(P) texfat(P) arc4 [last unloaded: compat] Aug 15 20:59:47 Media_Drive klogd: [ 497.168793] [<8002d4ac>] (unwind_backtrace+0x0/0xf0) from [<80053830>] (warn_slowpath_common+0x4c/0x64) Aug 15 20:59:47 Media_Drive klogd: [ 497.178569] [<80053830>] (warn_slowpath_common+0x4c/0x64) from [<80053860>] (warn_slowpath_null+0x18/0x1c) Aug 15 20:59:47 Media_Drive klogd: [ 497.188498] [<80053860>] (warn_slowpath_null+0x18/0x1c) from [<7f309930>] (wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]) Aug 15 20:59:47 Media_Drive klogd: [ 497.199819] [<7f309930>] (wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]) from [<7f30df84>] (wl1271_cmd_wait_for_event+0x34/0x3c [wl12xx]) Aug 15 20:59:47 Media_Drive klogd: [ 497.212469] [<7f30df84>] (wl1271_cmd_wait_for_event+0x34/0x3c [wl12xx]) from [<7f30ea8c>] (wl12xx_roc+0x12c/0x174 [wl12xx]) Aug 15 20:59:47 Media_Drive klogd: [ 497.223885] [<7f30ea8c>] (wl12xx_roc+0x12c/0x174 [wl12xx]) from [<7f30ec00>] (wl12xx_start_dev+0x12c/0x164 [wl12xx]) Aug 15 20:59:47 Media_Drive klogd: [ 497.234671] [<7f30ec00>] (wl12xx_start_dev+0x12c/0x164 [wl12xx]) from [<7f30d2dc>] (wl1271_op_bss_info_changed+0x638/0xd78 [wl12xx]) Aug 15 20:59:47 Media_Drive klogd: [ 497.246887] [<7f30d2dc>] (wl1271_op_bss_info_changed+0x638/0xd78 [wl12xx]) from [<7f2bc044>] (ieee80211_bss_info_change_notify+0x16c/0x17c [mac80211]) Aug 15 20:59:47 Media_Drive klogd: [ 497.260680] [<7f2bc044>] (ieee80211_bss_info_change_notify+0x16c/0x17c [mac80211]) from [<7f2cac6c>] (__ieee80211_recalc_idle+0x11c/0x1ec [mac80211]) Aug 15 20:59:47 Media_Drive klogd: [ 497.275038] [<7f2cac6c>] (__ieee80211_recalc_idle+0x11c/0x1ec [mac80211]) from [<7f2cad58>] (ieee80211_recalc_idle+0x1c/0x40 [mac80211]) Aug 15 20:59:47 Media_Drive klogd: [ 497.287700] [<7f2cad58>] (ieee80211_recalc_idle+0x1c/0x40 [mac80211]) from [<7f2c9b8c>] (ieee80211_work_work+0x3dc/0x11d0 [mac80211]) Aug 15 20:59:47 Media_Drive klogd: [ 497.300000] [<7f2c9b8c>] (ieee80211_work_work+0x3dc/0x11d0 [mac80211]) from [<80065fe8>] (worker_thread+0x17c/0x228) Aug 15 20:59:47 Media_Drive klogd: [ 497.311010] [<80065fe8>] (worker_thread+0x17c/0x228) from [<8006957c>] (kthread+0x78/0x80) Aug 15 20:59:47 Media_Drive klogd: [ 497.319519] [<8006957c>] (kthread+0x78/0x80) from [<800299c0>] (kernel_thread_exit+0x0/0x8) Aug 15 20:59:47 Media_Drive klogd: [ 497.328054] ---[ end trace e932d55cb0a29ea9 ]--- Aug 15 20:59:48 Media_Drive klogd: [ 497.847786] wl12xx: WARNING Unable to flush all TX buffers, timed out. Aug 15 20:59:49 Media_Drive klogd: [ 499.387888] ------------[ cut here ]------------ Aug 15 20:59:49 Media_Drive klogd: [ 499.392606] WARNING: at /home/qsi/freescale/source/TI/R5_SP1_Maintenance_Release_1/compat-wireless/drivers/net/wireless/wl12xx/main.c:1532 wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]() Aug 15 20:59:49 Media_Drive klogd: [ 499.409652] Modules linked in: wl12xx_sdio wl12xx mac80211 cfg80211 compat ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter tntfs(P) texfat(P) arc4 [last unloaded: compat] Aug 15 20:59:49 Media_Drive klogd: [ 499.428188] [<8002d4ac>] (unwind_backtrace+0x0/0xf0) from [<80053830>] (warn_slowpath_common+0x4c/0x64) Aug 15 20:59:49 Media_Drive klogd: [ 499.437595] [<80053830>] (warn_slowpath_common+0x4c/0x64) from [<80053860>] (warn_slowpath_null+0x18/0x1c) Aug 15 20:59:49 Media_Drive klogd: [ 499.447696] [<80053860>] (warn_slowpath_null+0x18/0x1c) from [<7f309930>] (wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]) Aug 15 20:59:49 Media_Drive klogd: [ 499.458956] [<7f309930>] (wl12xx_queue_recovery_work+0x20/0x5c [wl12xx]) from [<7f30df84>] (wl1271_cmd_wait_for_event+0x34/0x3c [wl12xx]) Aug 15 20:59:49 Media_Drive klogd: [ 499.471598] [<7f30df84>] (wl1271_cmd_wait_for_event+0x34/0x3c [wl12xx]) from [<7f30ea8c>] (wl12xx_roc+0x12c/0x174 [wl12xx]) Aug 15 20:59:49 Media_Drive klogd: [ 499.483005] [<7f30ea8c>] (wl12xx_roc+0x12c/0x174 [wl12xx]) from [<7f30ec00>] (wl12xx_start_dev+0x12c/0x164 [wl12xx]) Aug 15 20:59:49 Media_Drive klogd: [ 499.494464] [<7f30ec00>] (wl12xx_start_dev+0x12c/0x164 [wl12xx]) from [<7f308fa0>] (wl1271_op_config+0x200/0x394 [wl12xx]) Aug 15 20:59:49 Media_Drive klogd: [ 499.505922] [<7f308fa0>] (wl1271_op_config+0x200/0x394 [wl12xx]) from [<7f2bb138>] (ieee80211_hw_config+0x138/0x144 [mac80211]) Aug 15 20:59:49 Media_Drive klogd: [ 499.517732] [<7f2bb138>] (ieee80211_hw_config+0x138/0x144 [mac80211]) from [<7f2c9c24>] (ieee80211_work_work+0x474/0x11d0 [mac80211]) Aug 15 20:59:49 Media_Drive klogd: [ 499.530061] [<7f2c9c24>] (ieee80211_work_work+0x474/0x11d0 [mac80211]) from [<80065fe8>] (worker_thread+0x17c/0x228) Aug 15 20:59:49 Media_Drive klogd: [ 499.540803] [<80065fe8>] (worker_thread+0x17c/0x228) from [<8006957c>] (kthread+0x78/0x80) Aug 15 20:59:49 Media_Drive klogd: [ 499.549260] [<8006957c>] (kthread+0x78/0x80) from [<800299c0>] (kernel_thread_exit+0x0/0x8) Aug 15 20:59:49 Media_Drive klogd: [ 499.557668] ---[ end trace e932d55cb0a29eaa ]--- Aug 15 20:59:49 Media_Drive klogd: [ 499.562567] wlan1: authenticate with 4c:5e:0c:11:f0:b3 (try 1) Aug 15 20:59:49 Media_Drive klogd: [ 499.562623] wl12xx: Hardware recovery in progress. FW ver: Rev 6.5.7.0.29 Aug 15 20:59:49 Media_Drive klogd: [ 499.569745] wl12xx: pc: 0x0 Aug 15 20:59:49 Media_Drive klogd: [ 499.572549] wl12xx: down Aug 15 20:59:49 Media_Drive klogd: [ 499.575088] wl12xx: down Aug 15 20:59:49 Media_Drive klogd: [ 499.577646] ------------[ cut here ]------------
Re: Media Drive losing network connectivityOptions
08-17-2015 09:59 AM you could try reloading the FW and see if anything changes. Other than that the drive may be going bad and would likely need to be replaced.
