When it gets power, is there a way to have the WiFi option to turn on automatically?
If you plug it into the AC charger it will start charging and turn on. The wifi take about 30 sec or so to turn on. If you are using a computer WiFi will not turn on because the WMD makes a data (MSC) connection with the computer. The WMD does not support simultaneous WiFi and MSC connections to the storage.
