Highlighted
Newbie
Accepted Solution
Creating folders
Is there a way to create folders on the media drive or a card using an iPad. At the moment I don't have access to my Mac or a PC.
Thanks.
Highlighted
SanDisk Guru
Re: Creating folders
No, you would have to create a folder using a computer.
Highlighted
SanDisk User
Yes, you can do this using an app like FileBrowser.
