Newbie
Can create folders with password using SecureAccess or another app?
Hello! Sandisk Connect Wireless Media Drive can create folders with password using SecureAccess or another app?
SanDisk Guru
Re: Can create folders with password using SecureAccess or another app?
No, SecureAccess will not work with the WMD/WFD
Newbie
I* have creat a password with my device and now I have forgot my password I have pic and doc that I need what should I do?
Moderator
You can reset the password to the original default "admin" by following the process here:
Resetting Your Wireless Media Drive
microsansa
