Wireless connection while USB is connected to a PC
Hi all,
I was wondering if it is possible to maintain WIFI connected while the device is connected as flash drive to  a PC computer. I have read the user manual and done some test but it isn´t possible or I didn´t succed on it.
Does anyone tried this or is it possible??
Thanks in advance,
no, the controller only supports one connection at a time you can connect either USB or WIFI but not both at the same time.
Do I just create a SSID, or do I have to locate it on my computer to set up & transfer files.
