Highlighted
Newbie
Re: Streaming videos
last question that might save a lot of money for me :-)
My friend gave me his WFD. so far good it's news but it seems that the stick is empty with no memory card in (he took it out and can't find it). he is sure that the stick was shipped with 64gb memory card. so i want to buy the the exact 64gb memory card the stick shipped with but i don't waht version shuld i buy. maybe the  SanDisk Ultra Micro SDXC 64GB? i looked at the WFD 64gb specs and couldn't find anything. can you help me?
Highlighted
Newbie
Could someone please answer my last 2 posts?
Many thanks in advance.
Highlighted
SanDisk Guru
In order to stream files larger than 4gb i need to buy only the 64GB version of the WFD or wireless stick who support exFat and NTFS. is it correct?
NTF is not supported by any device regardless of capacity. If you need exFAT support you will ahve to purchase the 64GB device.
another option is the wireless media drive who for my best understanding the battery life is 8 hours and the 32GB also support exFAT and NTFS?
NTFS is not supported with the Media drive either. All capacities do support exFAT though. Battery life is also better.
