Highlighted
Newbie
Please add a factory software sticky for this drive
Note to administrators:
Please add a sticky for the factory software for this device.
Thanks
Highlighted
SanDisk Guru
Re: Please add a factory software sticky for this drive
The FW files can be found at the following link
http://kb.sandisk.com/app/answers/detail/a_id/12876/
the factory reset process can be found at the following link
http://kb.sandisk.com/app/answers/detail/a_id/8700/kw/WFD%20factory%20reset
Highlighted
Newbie
Thanks for the reply,
The firmware update does not contain the software that came with the FWD that was on the SD card of the FWD. The FWD reset process does not reinstall the factory layout software. But all the same thanks.  Ill just do without. but if some kind soul out there has a copy of the software and can upload it to a link site that would be great.
Thanks
