Ugo
Newbie
Connection with Lumia (Win 8 or Win 10)
Is Sandisk Connect compatible with winphones an PCs running Windows 10?
SanDisk Professor
Re: Connection with Lumia (Win 8 or Win 10)
you can connect to the drive with the browser of the device using the given ip address of the flash drive, but bear in mind that you will have a limitation in the options you can use with the device since the full support is activated with the ios or android application.
Good Luck
#Missing the keyboard? Press F1 for help#
