Highlighted
Newbie
microSD card not recognized
Just bought the clip sport from Best Buy and it will not read the microSD card that I inserted. My computer reads it just fine and that's how I copied approx 8g of mp3's onto it (16GB total capacity).
Before I return the player, am I doing something wrong?
Highlighted
SanDisk Guru
Re: microSD card not recognized
Make sure the player is off, and only turn it on after the card is inserted.
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Highlighted
Newbie
yes, the player is off when i inserted the card. When I turned it on the screen said "refreshing media" but the microSD card does not show up anywhere in the menu and I can't see the songs on it.
Highlighted
SanDisk Guru
You might try a manual re-set--press the on button down for a full 30 seco0ds and then re-start the player.  (This is based on the procedure for the other Clips.)  Hopefully, that might help.
Highlighted
SanDisk Guru
Otherwise, you might try a re-format under the player's Settings.  (Note:  this will erase the player's contents and so transfer anything you want to save to your computer first.)
Highlighted
SanDisk Guru
Note that this player does not integrate the internal and external memory into 1 database like all other Sansa players do. You must navigate to the CARD menu option to view and play content stored there. If you scroll through the Main menu and have no CARD menu, try going into SETTINGS (possibly then SYSTEM SETTINGS) and look for a CUSTOMIZE option, Here you can turn off Main menu items you don't use, or don't want to see. It's possible CARD is turned off. You can toggle it back on and then you should be OK. Smiley Wink
Highlighted
Newbie
Just to be sure, is it formatted in FAT32?
Highlighted
Newbie
Thanks guys, i am a dummy and didn't realize the memory card had it's own menu. I found it and it works great.
Highlighted
SanDisk Guru
Glad to hear it!
Highlighted
SanDisk Guru
You're not a "dummy" at all--the non-integrated nature of the Sport's 2 memories is a change from earlier Clip players.
