Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Re: Won't turn onOptions
07-24-2015 01:03 AM Just curious: Have you pressed the power button once again right after the 2-minutes reset? Re: Won't turn onOptions
07-24-2015 08:06 PM
And so, I guess that the first recommendation with a problem player should be, "Put it in a drawer and come back in 48 hours" . . . .
