Highlighted
SanDisk Senior User
SanDisk Clip Sport AAC Problems
i have a sandisk clip sport and when i try to play a AAC File Format my MP3 player frezzes on me
can there be another upgrade to fix this i need help.
Highlighted
SanDisk Guru
Re: SanDisk Clip Sport AAC Problems
Highlighted
SanDisk Guru
How long is the file you are attempting to play?
Highlighted
SanDisk Senior User
Re: SanDisk Clip Sport AAC Problems and firmware 1.25
I was trying to play a 4minute.57second song
Also the new firmware version 1.25 gives an error that says
"No files found" under music
Is there another firmware update to fix this
Highlighted
Moderator
Hi panda1212,
You can download and install the firmware version SanDisk Clip Sport Firmware 1.22 again on the Sansa Clipsport MP3 player and check if it resolves your issue:
http://forums.sandisk.com/t5/SanDisk-Clip-Sport/SanDisk-Clip-Sport-Firmware-1-22-released/td-p/33593...
