SanDisk Guru
Re: Problems adding Podcasts to internal memory.
That's great infomation to know, for what seems to be a recurring isssue.  Thanks--
Newbie
I checked the tags on my mp3s and they are all ID3v2.3 as written by MP3TAG V 2.58.
Newbie
Check in tools>options>tags that it's not ID3v2.3 UTF-16. Just to be sure...
SanDisk Guru
Dave, you unfortunately have identified a limitation in the Sport's sorting, the length of the titles (after which the remainder of the title is ignored).  Sorry that you had to find this.  Unknown, at present, if this can be changed.
I wonder if a solution is to use the folder and card navigation options.
