Hi, after 2 Sansa Zip i wanted to test the new Sport model because of battery life who was a problem for me on Zip, but i’am badly surprised that a new model have lower quality for the reception of radios…, i test same station (in France) for 1/3 of station who work fine on Zip, on Sport the sound change from stereo to mono Many time, look like if i mode the cable of the headphone that can rarelly help, go sport with that…
Also there is a bug on preset of radio, sometime he go back to preset 1 when i’am on preset 15 or 16…, look like going after 100 MHZ is when that happen…
One thought as to the reception issue: as the player uses the earphones cable as the antenna, could your issue be due to the new Sport earphones? You could check this by using your old earphones with the player, and see if that helps.
