Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Problem activating Sandisk clip sport MP3 with AudibleOptions
09-25-2019 07:11 AM Have already tried to activate through Audible without success. Purchased this as l was told this was compatible. Can you help? Re: Problem activating Sandisk clip sport MP3 with AudibleOptions
09-25-2019 10:43 AM Have you consulted the Audible help center and/or download & install the AudibleManger onto your computer? Re: Problem activating Sandisk clip sport MP3 with AudibleOptions
09-26-2019 10:31 AM Yes, l spoke with Audible this morning they can’t help so they suggested l get in touch with you guys Sandisk!
10-05-2019 07:43 AM It will not read SD card it says updating media information and freeze the screen will stay locked on that. I have attached several pictures of the screen displays and zoom pictures of the device, as requested. Is there a format that I can download to a SD card or otherwise to reprogram the device? I've already done several factory reset. Re: Problem activating Sandisk clip sport MP3 with AudibleOptions
10-07-2019 10:13 AM
Factory reset will do nothing. All it does is reset the personal settings you have set on the player.
Have you tried formatting the player itself? Re: Problem activating Sandisk clip sport MP3 with AudibleOptions
10-14-2019 04:32 AM hey did you ever sort this out? |
