Highlighted
Newbie
Jabra Elite 65t drops while running and not cycling?? Is Sport Plus sensitive to 'irregular' motion?
Highlighted
SanDisk User
Re: Jabra Elite 65t drops while running and not cycling?? Is Sport Plus sensitive to 'irregular' mot
Yes, no nerd sports are allowed.
Highlighted
Newbie
Do you mean you have some cuts while running? I'm facing same issue!
Have you solved it?
Highlighted
Newbie
Im most recently using Jaybird X4 and I’m experiencing cutting too. The Bluetooth receiver is on the left side of my neck with the Jaybirds. If I clip the player at my waistline on my left side, I get mostly good results. Completely unusable on my right side. Bending over stretching will cause them to cut out (maybe similar to being on a road bike? I could see the player in your rear jersey pocket could have proximity issues.
Not an issue with my iPhone, I can walk across the gym without issue. They either have a crap Bluetooth hardware implementation or buggy firmware (both?)
