Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
![]() Posts: 0
![]() MobileMateSD+ 104 and my SD cardOptions
12-15-2007 07:46 PM
I just bought the new MobileMate to use with a new Sandisk 2GB SD card. I am trying to copy pictures from my desktop to the card. It gets to about 232 MB worth of pics and won't let me copy any more than that. Windows recognizes that there are 1.89GB worth of memory on the card.
I simply inserted the SD disk into the mobilemate and then plugged it into my pc. It loaded and was correctly recognized as working. I don't know what I'm doing wrong. The only thing I noticed was that the SD card has a FAT file system and I can format it in FAT32. I haven't done anything like that to it, mainly because I don't know if that is something that needs to be done. Solved! Go to Solution. ![]() Posts: 0
Re: MobileMateSD+ 104 and my SD cardOptions
12-15-2007 07:53 PM
The error message I get when trying to copy pictures to the SD card is as follows:
"Cannot copy IMG_0059: The directory or file cannot be created." This is the error message no matter what picture is selected. ![]() Posts: 0
12-16-2007 09:04 AM I had the same issue. I formatted the card with FAT32 formatting and the problem was solved. I hope this helps, good luck!
![]() Posts: 0
12-18-2007 07:04 PM
thank you! I did just that, and everything is great!
![]() Posts: 0
12-23-2007 02:53 PM How do you format it with FAT32 formatting?
![]() Posts: 0
12-23-2007 03:52 PM
You need to have the card plugged in to your computer. Just go to "My Computer", find the card and right-click it. From the drop-down menu you should see a choice to "Format..." or something like that.
![]() Posts: 0
01-19-2008 08:53 AM
Is this why Sandisk doesn't spec the SD 104 for SDHC ?
I noticed that they changed the website page for SD104... it used to say compatible with SD and SDHC but they changed it to read just SD. (they also changed the picture back to what the SD103 looks like). What's going on? This is the new webpage: SanDisk MobileMate™ SD™ Plus 5-in-1 Reader SDDR-104-A11M ![]() Price: $19.99 » Buy Direct » Find a Retailer » Compare Online Retailers » Customers outside the U.S. and Canada, please click here Transferring your photos, videos, music and data files between your digital devices and your PC is quick and easy, wherever you go, with SanDisks MobileMate SD Plus 5-in-1 Reader! Just plug your flash memory card directly into the reader and youre ready to roll. The SanDisk MobileMate SD Plus 5-in-1 Reader works with the following memory cards, without the need for an adapter: Advanced Features:
![]() Posts: 0
01-21-2008 03:41 PM
That looks like a misprint to me because that is the 103 and not the 104 in the picture.
![]() Posts: 0
![]() Re: MobileMateSD+ 104 and my SD cardOptions
01-21-2008 03:42 PM
The other solution is to put a couple of folders in the root directory and divide your pictures into different folders. The Fat format has a limit to how many single files can be in a directory at one time. FAT32 resolves this issue as well.
