Highlighted
Accepted Solution
Imagemate 5in 1 reader with RS MMC
Hi
Has anybody used the card reader to read RS MMC card of nokia phone? I see that the card is small and I am afraid of losing it within the card reader. Would be grate if somebody can share their experience.
Thanks
Highlighted
Re: Imagemate 5in 1 reader with RS MMC
Depending on what reader you are actually talking about, you may be able to insert it in with out the adapter you should have gotten.  Else, like I said, you should have gotten an adapter to make it a full size MMC card.
The SDDR-103/104 should be able to accept the card without the adapter, it should go in, but not all the way.
