Highlighted
Accepted Solution
ImageMate 5 in 1 Reader -- Need Installation CD
I own an ImageMate 5 in 1 Reader (Model Number SDDR-99).  I want to install it on a different computer (running WIN XP sp2) but have lost the installation CD.
Where can I get anoter one?
Thanks,
     Hal
Highlighted
Re: ImageMate 5 in 1 Reader -- Need Installation CD
The drivers for this reader are native to Win XP SP2, so you don't need an installation disc...
Highlighted
Thank you, WarLock...
Can you tell me about the button on the Reader, and how it's used?
Thanks,
    Hal
Highlighted
The button on the reader is used with the TransferMate software to allow one touch transfers of files to/from the reader.  This software you may have to contact SanDisk directly to obtain...
Highlighted
Thanks, WarLock...
