Highlighted
mau
Newbie
Card reader for 32gb sdhc card & and usb 3 version.
i have a sandisk 32gb extreme pro sdhc memory card.
is your all-in-one reader the recomanded reader? ..for said card.
if yes, is it capable of the card's maximum rated speed of 45mb/s? reading the notes at the bottom would suggest NO, with the max being 34mb/s. if that is indeed correct, don't you think that's crap? shouldn't a reader made/sold by sandisk be able to read/write a sandisk product (memory card) at said product's maximum specifications?
and on the same subject, how long before there is a usb 3.0 model of your reader/s?
usb 3 is not that new now and will become de facto soon enough. you can use a usb 3 device in a usb 2 port and it will work, albeit slower, but at least you can't claim it's because most people still don't have usb 3.
Highlighted
SanDisk Guru
Re: Card reader for 32gb sdhc card & and usb 3 version.
sandisk has an express card reader that is recomended for the Extreme pro cards. USB 2 readers imply cant reach the speeds the card is capable of. I have not seen a USB 3 reader from sandisk but I am sure one is in the works.
Highlighted
mau
Newbie
in the words of those apple vs windows ads; ===> i'm a pc...
with that in mind i quote one of the device requirement for what you linked:
Notebook or desktop computer with ExpressCard™ 34 or ExpressCard™ 54 slot
wait what? what slot on a pc?
i have pci and pci express and that's it baby. or..?
Highlighted
SanDisk Guru
No express card slots are not PCI express card bus on the motherboard.
http://www.expresscard.org/web/site/standardsummary.jsp
