api
Newbie
6-in-1 PC Card Adapter
Hello
I have  6-in-1 PC Card Adapter  but I cannot read a Kingston  SD 8GB . I  can  read  a  Kingston  SD 1 GB.
The pc-card adapter  can I use like Ready Boost ?
SanDisk Guru
Re: 6-in-1 PC Card Adapter
Most likely your adapter is too old to support the SDHC format, which anything above 2GB is. I'd get a new, more current one.
Also realize anything you get today will not support to new, soon to be popular SDXC format (>32GB), so you'll eventually have to get another one if you plan on using those cards. That may be a couple years down the road though.
