Newbie
220 Power Voltage compatibility?
About to go to Turkey. Can anyone tell me if the Clip is 220 power voltage compliant?
Know I will need a plug adapter but don't know about the voltage?
Thank you
SanDisk Guru
Re: 220 Power Voltage compatibility?
as long as the adapter has an output of 5V .5Amps you should be fine. if you are worried take a laptop and charge it from there.
