SanDisk User
Re: What is your experience with product compatibility?
microSD cards work with PSP's when using an adapter for the proper type of memory card.
Sansa Clip+ 8GB + 8GB microSD formatted by phone/4GB microSD Card|Sony PSP 32GB microSD in a Memory Stick Pro Duo adapter|Samsung SGH-T839 (Sidekick - Tmobile)|Samsung Gravity T (Father is now using it)|(headphone jack not working right) 4GB Sansa Clip+
Newbie
The information provided by Sandisk for the Nikon D50 is inaccurate. It states that the D50 can use either SD or SDHC cards. It cannot. It can use only SD cards, and to a maximum of 2Gb.
Unfortunately, the only cards that Sandisk currently offers that are compatible with the D50 are the slow C2 cards. I just got off the phone with Sandisk support and they confirmed this.
Grant
SanDisk Guru
Grant
Can you let us know where you see that info? I looked at the compatiblity tool and it shows only 2GB cards listed for teh D50.
Newbie
Re: What is your experience with product compatibility? - Firmware Updater with Windows 8 preview
Just to advise that I have just installed the Firmware Updater and as soon as I start it, a message comes up saying that it is not compatible.  There does not seem to be any way of overcoming this using a compatibility mode and it makes no difference if I open it as Admin..
I am using the preview version of Windows 8.
Newbie
I purchased the 64GB SanDisk Ultra microSDXC™ UHS-I card for my Galaxy Note 2 (recommended as compatible on the SanDisk website). The card seems to read and write just fine. However, with this card in the phone, the phone status changes to Modified and I can no longer receive OTA software updates. Also, the Samsung Video Hub will no longer allow me to switch my storage to the external card (something I am able to do with a 32GB card from another manufacturer).
