Highlighted
Newbie
Not reading 64GB Ultra micro sdxc
I have just purchased a Sandisk Ultra 64GB Micro SDXC card but when using in my Archos 101XS tablet the card will not mount and therefore I cannot use it, Sandisk told me before purchase that the card IS compatible with the Archos, I have tried formatting using my PC to exFAT but this still does not work. any help would be greatly appreciated,
Best wishes to all for 2013.
Highlighted
SanDisk Guru
Re: Not reading 64GB Ultra micro sdxc
Is the card reader/adaptor you're using (if any) SDXC-compliant?
Highlighted
Newbie
Try formattig the card to FAT32 on your PC  . You  can also try formatting the card with the SD formatter programme from sdcard.org
Highlighted
SanDisk Guru
[ Edited ]
Thnaks for your excellent suggestion Dan, but just a tip . . . please note the date of the post/thread you intend to reply to before posting. Replying to an over a year-old thread is rarely helpful.  Smiley Wink
