Which way does the micro card go? Micro SD into adaptor for SD.
I have to ask. I dont want to risk getting it stuck the wrong way. Does the print on the cards both face the same way?
Re: Which way does the micro card go? Micro SD into adaptor for SD.
the card will only fit into the adapter one way. but to answer uyour question yes the card goes in print side up.
