SD Adapter Issues
Can't get any owned device to read 4gb micro sd within the sd adapter.  I even replaced the adapters and took the card/adapter to verizon store for verification but they could not get it to read either.  The 4gb micro sd works within the EnV2 phone just fine - but not within adapter(s).
My SD reading eqiuipment that I tested the adapter(s) with:
- HP psc2410 all-in-one to read to my Dell Dimension 4550
- Dell Axim x50 hand-held pc
- various digital still/video cameras
Nothing reads the card w/ adapter just the phone with card alone.
Any ideas before I spend more money? (probably not on any more sandisk products)
Re: SD Adapter Issues
The devices you are attempting to use it in are not SDHC compatible, or the adapter is defective.  One of those is the answer.
Were you able to resolve your problem.? I have the same issue
your devices are not SDHC compatible. There's no problem with the card since it's detected by the phone.
