Accepted Solution
How to use WPA on Sandisk CF 128Mb Wifi Card
Hello !
Did somebody know how to use a WPA Acess with the Sandisk CF 128 Mb Wifi Card.
I use a pocket PC on Windows 2003.
Thanks very much !
Re: How to use WPA on Sandisk CF 128Mb Wifi Card
As I remember it (it has been over a year since I played with one of those) the CF card is WEP only.  And, since SanDisk abandoned Wi-Fi in 2003, there is not any update to the firmware of the card.
ok. thank you !
No interface for that card for WPA.
