Accepted Solution
Compact Flash PC Card Adapter not working with Vista SP1
Just installed Vista SP1 and now the PC Card adapter is not working.
It says it can not find the software
Any suggestions about how I can get this to work other than uninstall SP1
Thanks
Re: Compact Flash PC Card Adapter not working with Vista SP1
Probably going to have to uninstall SP1, Microsoft must have messed up the drivers for the memory card (there are no drivers for the adapter, it has no electronics in it).
Pc-Card works on my computer with Vista SP1 but it terribly slows down the whole system when reading/wrinting to the card.
Very strange behaviour...
Has anyone an idea ?
16-bit PCMCIA devices are very slow, which is why they have been phased out.  Nothing you can do about it.  When I am transferring using my 4GB CF card, my whole computer becomes very slow, too.  I just usually start the transfer and then walk away and do something else.  Or use my USB reader when I can.
