Highlighted
Accepted Solution
Problem with Cruzer SanDisk
I recently have been having a problem with my SanDisk Cruzer Micro 512MB.  When I was using it a couple of days ago, the window just shut down when I went to open a file and it hasn't returned since.  It lights up when I plug it in, but does not automatically read or show up under "My Computer".
Near the same time, I installed a printer that has a card reader in it. But, I don't remember if it was acting up before or after I installed the printer....I think it was acting up before I installed it though.
I have tried plugging it in to several computers...all of which make the thumb drive light up, but it never actually reads it.
Any help would be appreciated.
Thanks
Highlighted
Re: Problem with Cruzer SanDisk
Try checking for it in Device manager? If it shows up, the properties will probably tell you what's going on.
Highlighted
No luck. It's not showing up in the device manager. I am guessing that all info on it is lost.
Highlighted
Contact SanDisk Tech Support...
Message Edited by Warl0ck on 03-22-2008 10:48 AM
