I have problems with my USB flash memory Cruzer Micro 2GB
My USB flash memory Cruzer Micro is recognized for all computers but i can not copy anything, i tried to format it in Linux and Windows and i could not, the message was "I/O error during the writing in /dev/sdb". How i can fix my flash memory?. I will appreciate your help.
Re: I have problems with my USB flash memory Cruzer Micro 2GB
sounds like a bad device.
 Waddup Shrek,
What distro of NiX are you running? I am assuming if you know Linux that You may under stand he following, forgive me if I am wrong......
Throw it on your Win box, and run a check Disk for errors on the device and repair any errors found.
 On NiX - In a terminal run  "format dev/sdb/"
Make sure of the mount point however and the file sys format......
If you format on NiX in ext3, win may not recognize it correctly, Make sure its "FAT"
Hope this helps a little
Lj
yes i have a great problem with ma Cruzer Micro 2GB flash memory
the flash memory is readed on ma Windows XP 0 capacity not 2GB!!!!
i don know what to do ...please if any one know anything can help please help me
i bought this Flash yesterday From a super a market and i didn't use it except once on ma own PC (as a test)
it succeded in the test ... n failed in real life !!!
