Accepted Solution
Cruzer with replaceble SD card
I have a Cruzer wich was sold with a 128 Mb card in it.
What is the max size of the card in Mb or Gb for this Cruzer ?
Model number SDCZ1
Part nr 20-90-00067
Thanks in advance
Chris
Re: Cruzer with replaceble SD card
O.o Good god, those haven't been made in...years. I'd call tech support and see if they can tell you.
Sorry I don't eat them, just use it in the proper way !
Maybe at the western side of the Ocean it has been earlier in the shops.
Message Edited by chris0745 on 02-28-2008 07:03 AM
128 i think was the highest it took.  I haven't used one in so long.  Did you try any other higher capacity cards in it?
Is this some kind of hidden code? Are you trying to tell us that you've been abducted? If this is true, don't say yes, just say "broccoli"!
i think it can take up 1GB cards or even up to 2GB cards.
