Accepted Solution
Cruzer Micro 1GB
I have a cruzer micro 1GB flash drive. When i insert it into my dell laptop with windows vista, it comes back with the error of needing to install drivers onto the laptop. I do not have drivers and I cannot find any. It does not seem to recognize what the drive is. This problem is with several flash drives that I have tried. If anyone knows the solution to this problem it would be a big help. Thank you.
Re: Cruzer Micro 1GB
There are no drivers, they are built in to Vista.
If you keep getting a Found New Hardware wizard, you may want to try this hotfix from Microsoft: KB940199
There is a known issue where Vista will not load the drivers for USB devices.  That hotfix is suppose to fix it.
Thank you, that was exactly what i needed.
I tried the KB download from Microsoft, but that didn't help me with my mobilemate card reader :smileysad:
