Accepted Solution
Can USB connector be repaired on a Cruzer flash drive
The USB connector on my Cruzer 2.0GB flash drive is damaged.  Can this be repaired?  If so how & where can I contact someone about this?  VERY important on drive - need to access it.
Can anybody help?
Re: Can USB connector be repaired on a Cruzer flash drive
You should contact SanDisk Technical Support at 1-866-SAN-DISK (726-3475) and they may be able to help you or even replace it if it's still under warranty...
Here is a link showing wiring for USB Connector.
http://pinouts.ru/Slots/USB_pinout.shtml
this is standard
These guys have resoldered 3 out of 4 flash drives for our department, one could not be fixed ( broken board ) they charge less than $100 to resolder, and you can download your data as soon as they are finished USB flash drive repair shop
There is also a guide for do-it-yourself folks, but I can't even see the joints, much less get a hot iron on them.... you need a microscope
crazy solder joints huh?
broken usb repair
