Highlighted
Newbie
What's the difference between these? Decode part numbers?
I'm looking for help decoding these Sandisk part numbers, so I can tell what the difference is between them:
SD Ultra Plus 32GB:
SDSDUSC-032G-AN
SDSDUP-032G-A
microSD Ultra Plus 32GB:
SDSQUSC032GANCM
SDSDQUP-032G-AA
Any info on what the differences are would be great!
Thanks!
Highlighted
SanDisk Professor
Re: What's the difference between these? Decode part numbers?
since this is really related to the specification of the product i think it should be better if you would ask sandisk directly to receive a perfect clear answer on it since its a user forum and i doubt that a user can decrypt the sku of the sandisk products.
here you can send your question:
http://kb.sandisk.com/app/ask/session/L3RpbWUvMTQ2MDk2Mjg5Ny9zaWQveGdtbDdqT20%3D
Good Luck
#Missing the keyboard? Press F1 for help#
