SanDisk Ultra 32gb MicroSD HC1 FOrmats to 1.42gb
Trying to reformat my card to FAT file system but when i format with windows 7’s formatter it only allows a capicity of 1.42gb.
Help plz
You should format it as FAT32.
Hi Invader, how did FAT32 reformat went for you? Are you sure the capactiry says 1.42 GB or is it the free space?
Hi I reformatted with a formatter from as card association and it worked properly. For some reason the standard formatter that comes with windows doesn’t work.
