Micro sd card not showing up
Just bought a 128g imagemate pro and it isn’t showing up in the drivers device management or disk management. Using the as card adapter it came with and input into Lenovo laptop card reader.
If your SD card is not showing up in Disk Management or Device Manager, it would be caused by hardware problems, faulty USB port or SD card reader.
So first of all, please try a different SD card reader or another USB port to see if your SD card is working.
After that, if your SD card is still not showing up on your computer, the card might be physically damaged. You can do nothing but send it to a local repair center. Otherwise, replace the SD card with a new one.
