Newbie
Accepted Solution
Memory card replacement
I want to replacement of 16GB Mac card
Newbie
Re: Memory card replacement
It's not dedecting the mobile
SanDisk Guru
If you are referring to a SanDisk memory card, you need to contact SanDisk directly and open an RMA (Return Merdandise Authorization) claim.
This is a user's forum only. SanDisk's contact info is here.
