Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Re: How to repair micro sd 16gb card? It shows 31mbOptions
05-17-2019 06:18 AM
05-19-2019 03:44 AM Windows Administrative Tools -> Computer Management -> Disk Management
Find the SD card, right click and delete all the partitions on the card (it might show several) remove them all until it's got none, then add a new Simple Partition taking the full size of the card.
Some tools like Win32 Disk Imagers change the disk layout so you need to manually restore it. Re: How to repair micro sd 16gb card? It shows 31mb[ Edited ]Options
05-19-2019 12:36 PM - edited 05-19-2019 12:38 PM
I tried to read it using car reader on my pc. Some readers cannot see this card, but some can see and ask format it, when the format dialog is appeared is shows that card has only 31mb of storage and I can format it in fat or ntfs. But if I click format I'll see the error message. Also I try to insert card into Nokia N96. It also can see only 31bm can format it and I can write something but cannot read. If I turn off the phone and turn on it again, or release insert the card the phone asks me format it again. Re: How to repair micro sd 16gb card? It shows 31mbOptions
08-20-2019 11:12 PM I had a problem with original/current microsd storage, quite different, but I think the solution might help, or at leasr clear things out. I had a 16 gb microsd on my tablet a while ago, but bought a new phone so I thought it'd be better to have it on that instead, but I noticed that it only shows 8gb, after some unsuccessful research I remembered that I partitioned the disc so that I can use link2ds on my tablet.
