Highlighted
Newbie
Card Full- Extreme Plus 128GB
Bought it and put it in my drone. It said it was full from the start. Also, packaging says Download Required. I'm lost. Advice on how I can start using this?
Highlighted
SanDisk Guru
Re: Card Full- Extreme Plus 128GB
try formatting it in your drone or use a computer if the drone does not support formatting the card.
no download is required to use a card. the only thing with the card that requires a download is the free trial of data recovery software.
