Highlighted
Newbie
Accepted Solution
64GB Sandisk Ultra Microsd Error 0x800701E3
I have been using a SanDisk 64GB Micro AS for more than 2 years and there was no problem. Recently I'm not able to copy any files to the SD card although Ii can view files or even copy files already on the SD card to my computer. I also cant delete files on the SD card or format it.
And when I try to copy or delete files it displays the error code 0x800701E3 and says that there is hardware failure. And I want to know if there is permanent hardware damage or if it can be fixed, Thanks
Highlighted
SanDisk Guru
Re: 64GB Sandisk Ultra Microsd Error 0x800701E3
Most likely can't be fixed, however it can be replaced under warranty.
