Highlighted
Micro SDHC 4G card help
Yesterday i buyed myself a 4G Micro SDHC card but one or the other way i can't put music on it or atleast i don't know with wich program i need to do it
I'm very new with this kind of stuff so sorry if its a beginners question
Could somebody give me some more information about it and maby wich program i need many thanks
Highlighted
Re: Micro SDHC 4G card help
You should be able to just drag and drop the music you want onto the card itself. Just open up my computer and you'll see your drive listed. You will need a card reader inorder for you to connect it to your computer.
On a side note, if you're going to use the card to store music on an MP3 player make sure that the device suppports SDHC cards.
Highlighted
are u working with SDHC compatible card reader?
Highlighted
Make sure your card reader and MP3 player support SDHC...
