Highlighted
CopyRight?
ok..so i just got a new microsd 1G memory card. My computer reads it but when itry to drag a music file into it it says that the copyright is protected any suggestions?
Highlighted
Re: CopyRight?
it sounds like your music is either copy or DRM protected. first you will have to make sure your device is MTP compatible and use WMP to sync the music to the card. or look for an application that will crack the DRM (although this is technically not a legal course of action).
