2GB microSD/TransFlash problems
My microSD just arrived for my Samsung A516 and it says to just insert the card into the phone's slot and use normally. However, whenever I try that and try transfering files to my phone, a window pops up immediately and says "insufficient memory." I've tried formatting it by it seems that my computer doesn't recognize the card.
Any suggestions?
Re: 2GB microSD/TransFlash problems
It should show up as a removable disk or the name of the card/phone in "My Computer" and depending on what data you are saving to it, there should be designated folders inside of the drive.  Also, what kind of card reader are you placing it in?
