1GB card stuck in adapter
I bought the 1GB SD card with MiniSD and MicroSD adapters.  I put the card into the smaller of the two adapters, copied everything off my old phone, took the adapter and card out of my old phone, and now I can't get the card out of the adapter.  Is there a secret handshake or special trick that I don't know about?
Thanks for your help!
LauraF
Re: 1GB card stuck in adapter
no secrets the card should pull out easily. i have had to use my teeth a few times but be careful you dont want to end up with any chipped teeth.
Wow - teeth?  It worked!  The card came out, didn't get swallowed, and is now in my new phone.  Many thanks!
LauraF
