Accepted Solution
Sandisk Nintendo Wii SD card Write speed
Im curious what is the write speed of the Sandisk  Nintendo 2.gb Wii SD card  found here.
I have read descriptions and reviews and I can't find anywhere the writing speed.
Can someone enlighten me?
Thanks
Re: Sandisk Nintendo Wii SD card Write speed
SanDisk only speed rates their high end performance cards. There is no stated write speed for the Nintendo Wii SD card unfortunately.
the write speed on a wii sd card is 3mb a sec
a 1gb wii sd card costs about $50
so save your money and buy a 2 gb sd card at www.tigerdirect.com  for about $20 and writes at 10 mb a sec
Did you speed test the wii card? If so what did you use to speed test it and what type of reader did you use with your computer? Where do you shop that the wii sd card costs $50? Walmart sells them for $25 I think I've seen them cheaper than that on sale at Gamestop as well.
http://www.walmart.com/search/search-ng.do?search_constraint=2636&search_query=sandisk+wii&Find.x=0&...
