Highlighted
Accepted Solution
Memory Stick PRO Duo
I went and renamed my folders on my memory stick PRO duo card (1gb) and now I can't view the pictures I have in that folder on my camera. Does anyone know why?
Thanks
Highlighted
Re: Memory Stick PRO Duo
Cameras use very specific folder file names.  You can not rename them and expect the camera to see the pictures anymore.
Also, for future reference, because of this you usually can not copy files over to the card from a computer and view them either.
